SpenB Posted June 4, 2013 Share Posted June 4, 2013 Morning all.Started the rear axle build last night - FINALLYIts a rear axle off a Disco 300Tdi.Question is: On the rear calipers i have a Bleed screw and a Brake line nut. But what is the bolt thats in the middle of these for please?Cheers,SpenB Quote Link to comment Share on other sites More sharing options...
Tanuki Posted June 4, 2013 Share Posted June 4, 2013 Morning all.Started the rear axle build last night - FINALLY Its a rear axle off a Disco 300Tdi. Question is: On the rear calipers i have a Bleed screw and a Brake line nut. But what is the bolt thats in the middle of these for please? Cheers, SpenB It's a bung to seal a drilled fluid-passage that connects between the 2 halves of the caliper. Quote Link to comment Share on other sites More sharing options...
porsche Posted June 4, 2013 Share Posted June 4, 2013 there you go Quote Link to comment Share on other sites More sharing options...
SpenB Posted June 4, 2013 Author Share Posted June 4, 2013 Ok thanks. i'll leave it there then. Cheers Quote Link to comment Share on other sites More sharing options...
