white90 Posted September 26, 2006 Share Posted September 26, 2006 I need to get some decent drill bits any suggestions/recommendations please Tony Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted September 26, 2006 Share Posted September 26, 2006 Titanium coated HSS …………… not cheap, but they keep a good edge and can be used for reasonably hard materials. If you can sharpen drills yourself, then ordinary HSS are fine for most jobs especially if kept in tiptop condition. On the lathe I use cobalt drills B) ………… but they are spendy. Ian Quote Link to comment Share on other sites More sharing options...
white90 Posted September 26, 2006 Author Share Posted September 26, 2006 toolstation have 19pc set cobalt for £21.02 sound ok? http://www.toolstation.com/shop/DrillBits/...its/d110/sd1230 Quote Link to comment Share on other sites More sharing options...
Les Brock Posted September 26, 2006 Share Posted September 26, 2006 Use the correct speed for what your trying to drill, trying to burn your way through on high speed does the drill edge no favours , let the tool do the work and use a decent cuttting fluid when drilling esp......stainless/8274 shafts etc Oh.....Colbalt are cracking drills Quote Link to comment Share on other sites More sharing options...
white90 Posted September 26, 2006 Author Share Posted September 26, 2006 no shaft drilling required as I now have one of these to fit: http://www.gigglepin4x4.net/8274/mainshaft.htm Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 26, 2006 Share Posted September 26, 2006 I use Dormer brand from my local fastenerrs place. Have fpund them to be superior to Woolworths(!) and from Black&Decker from B&Q. oh, they are coated with that yellow stuff - titatniium? Quote Link to comment Share on other sites More sharing options...
will_warne Posted September 26, 2006 Share Posted September 26, 2006 Tony, as above, Colbolt are lovely but pricey. Unless I'm drilling something hard I tend to buy normal HSS drill bits and then sharpen when I need to. Good cutting fluid is also well worth buying. 3 in 1 oil is pretty good for everyday stuff but Molyslip cutting compound is the dogs dangely bits. Quote Link to comment Share on other sites More sharing options...
