pwam2006 Posted June 16, 2013 Share Posted June 16, 2013 Hello all, Recently fitted a 300tdi auto from a disco into def90. The 90 is used off road heavily and when on steep slopes, the auto box jumps out of gear. However you can (by holding the button in) find the right gear again by moving the lever back a bit. Ie on a 30 deg climb 'D' is actually at about '3' on the selector. Any thoughts much appreciated. Ryan Quote Link to comment Share on other sites More sharing options...
teabag Posted June 16, 2013 Share Posted June 16, 2013 More info required.... are u saying the selector cable requires adjusting? How can an auto jump out of gear? there are only two gears you can select, 1st in postion 1 and reverse. Positions 2 3 and D the box selects a suitable gear within that band. Quote Link to comment Share on other sites More sharing options...
