muddy4x4xfar Posted June 18, 2013 Share Posted June 18, 2013 hi all, iv fit all the bulkhead wiring to my td5 defender im building, everything is fit correctly to my knowledge. but when it comes to turning the key on the ignition all i get is a battery light on the dash and nothing else doesnt even try cranking. . iv tried changing relays etc and no change any ideas what could be going ? im at my witts end and loosing sleep over this so any helps much apprieciated. thanks Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 18, 2013 Share Posted June 18, 2013 Alarm/Imobiliser locking it all out ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 18, 2013 Share Posted June 18, 2013 Have you fitted the earth from the ECU ? Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted June 18, 2013 Author Share Posted June 18, 2013 hi thanks for replies, all earths are fitted as they should be , and alarm box is fitted and was working before . Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted June 18, 2013 Author Share Posted June 18, 2013 the heater plugs don't kick in or the fuel sender unit . its so confusing Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 18, 2013 Share Posted June 18, 2013 Is the crash inertia switch plugged in/ tripped? Pressing the top of it down resets it. Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted June 18, 2013 Author Share Posted June 18, 2013 never thought about that ill give it ago cheers. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 18, 2013 Share Posted June 18, 2013 Are you getting any normal auxiliary power? IE heater blower, radio etc? Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted June 18, 2013 Author Share Posted June 18, 2013 hi no I arnt all I get is the red battery light on the dash board Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 18, 2013 Share Posted June 18, 2013 must be a problem with the ignition switch or its wiring then? Regardless of ECU's, immobilisers and alarms, the aux electrics should still work with the ignition on. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 19, 2013 Share Posted June 19, 2013 whats the temp guage doing? sounds very much like you need to reset the crash switch, have you connectred the earth thats under the expansion bottle? Quote Link to comment Share on other sites More sharing options...
