nige90 Posted June 19, 2013 Share Posted June 19, 2013 Friend bought an 02 Freelander extremely cheap due to head gasket failure. Chap who had it removed the engine and bought a replacement from an MGF. He then had this engine reconditioned by a (alledged) engine shop but never got round to fitting it. We fitted it two weeks ago but cannot get the sod to run, it tries but that's all. All plugs are sparking and all injectors are spraying a nice pattern. Downpipes get hot so something it happening. Pull the injectors out and hold them half way over the ports and it will run very roughly but not rev. This implies it's running rich to me. Changed O2 sensor, MAP, temp, cam and crank sensors and still no joy. Compression is good and cam timing is definately correct. Unless I'm missing something it can only be ECU. I'm a mechanic by trade BTW but am absolutely stumped. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted June 20, 2013 Share Posted June 20, 2013 Idle-speed control valve stuck closed? This would give the effect of an "over-choked" engine: usually at cold-start the ISCV gets opened to give extra air for a slightly faster idle: your lifting an injector is allowing extra air in. Have you also fitted the MGF ECU or are you still using the original 1.8 Freelander one? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 20, 2013 Share Posted June 20, 2013 Sounds like everything is working but the ECU is injecting too much fuel. Which probably just means something is making it think it needs to inject more fuel. That could be a bad MAP sensor/connection, bad coolant or air temperature sensor. Go for the cheap stuff before you start swapping ECU's. Quote Link to comment Share on other sites More sharing options...
defv890 Posted June 21, 2013 Share Posted June 21, 2013 Is it a Vvt mgf lump if so u should use the mg ecu To match the engine Quote Link to comment Share on other sites More sharing options...
nige90 Posted June 26, 2013 Author Share Posted June 26, 2013 Not a VVT and don't have the MGF ECU. Removed idle valve, no difference and the valve can be seen opening. So that's every sensor etc now replaced so can only be ECU. Quote Link to comment Share on other sites More sharing options...
