missingsid Posted July 2, 2013 Share Posted July 2, 2013 Found this on the thingy and stole it! Defender 90-110 Workshop Manual extract for LT77, LT230R, LT95, LT85 and 230T. Trouble is I can only zip it to 5.5MB and the linit is under 2MB here? is there a way of getting it uploaded? Marc. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 2, 2013 Share Posted July 2, 2013 You can stick it in Dropbox? Quote Link to comment Share on other sites More sharing options...
kiwimark Posted December 19, 2013 Share Posted December 19, 2013 How did you get on Josh? I have exactly the same issue, and have had the gearbox reconditioned with a new 2nd gear put in and it is still scrunching from 3rd down to 2nd...... Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted December 20, 2013 Author Share Posted December 20, 2013 Hi mark, there's been no real developments on this as I've basically learnt to live with it, and try to teach others to master it. My local specialists are able to do it but i would shudder to think of the cost! Are you running engine oil (20w-50) in the box? If you run anything else than engine oil, the shifting will suffer. I see your in Marlborough, what part? I have relatives in Blenheim who i'm visiting soon. Josh Quote Link to comment Share on other sites More sharing options...
Jmacc Posted August 16, 2022 Share Posted August 16, 2022 Good day We have an lt95 but it is without it's display screen. Can it run without the display screen ? Quote Link to comment Share on other sites More sharing options...
western Posted August 16, 2022 Share Posted August 16, 2022 50 minutes ago, Jmacc said: Good day We have an lt95 but it is without it's display screen. Can it run without the display screen ? LT95is a manual gearbox, it does not have any electrical display screens at all. 2 Quote Link to comment Share on other sites More sharing options...
simonr Posted August 19, 2022 Share Posted August 19, 2022 On 8/16/2022 at 8:50 PM, Jmacc said: Good day We have an lt95 but it is without it's display screen. Can it run without the display screen ? It can run without the display. If you want a display though, the best option is to buy the biggest TV you can find. One with a tube is better than a flat screen - as the gearbox is fairly old, an older TV has better compatibility. You need a big TV because the signals coming out of an old gearbox are very weak - the big screen helps you to see them. You'll might need an inverter to power the TV (unless it runs on 12V). Have a look at the oil filler plug on the side of the gearbox, to see if it has an antenna connector in the middle. If not, don't worry - just unscrew the filler plug and push the connector through the hole. Push the wire in as far as it will go - you might need a longer wire. Stuff an old rag into the hole to stop the oil leaking out. Switch on the TV and tune it to a channel without any signal. Start the engine and you will see everything the gearbox has to offer, display wise. Si 1 2 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 19, 2022 Share Posted August 19, 2022 Perhaps it's this.... 1 Quote Link to comment Share on other sites More sharing options...
