need4speed Posted June 29, 2013 Share Posted June 29, 2013 Just been having a quick look at how im going to wire my Bosch alternator up. Looking at RAVE it shows a Brown wire going to starter motor. It also shows a Brown/Yellow going to instrument pack and a Green/Yellow going to a header. I have attached a pic (sorry for the rubbish quality) showing what i actually have at the back of my alternator. You can see that on the 2-pin plug, only 1 pin is utilised? On the alternator there is a B+ which i presume is the Brown to starter? There is also a W and D+. The W appears to be used but the D+ is not. Im not sure what the W and D+ are for. Im making a guess that W is the dash warning light and D+ is for a tacho signal? Quote Link to comment Share on other sites More sharing options...
western Posted June 29, 2013 Share Posted June 29, 2013 this should help W = rev counter signal [tacho] connection B+ = main output from alt to battery/starter D+ = charge warning light Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 30, 2013 Author Share Posted June 30, 2013 Thats great. Thanks Ralph Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 30, 2013 Share Posted June 30, 2013 Its surprising that D+ isnt used, as most alternators use the d+ line to excite the field coils. Looking at your pic, the connection thats present is in the D+ point is it not? Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 1, 2013 Author Share Posted July 1, 2013 No. Remember im holding the connector upside down in the pic.... Also, D+ will be getting used as i will be connecting the dash warning light to it. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 1, 2013 Share Posted July 1, 2013 its upside down in two dimensions though.... Look at where the locating tag is in relation to the tag on the alternator. It wouldnt make any sense for it to have only W in its original application. Quote Link to comment Share on other sites More sharing options...
Bingy Posted July 2, 2013 Share Posted July 2, 2013 Thanks for the info guys, very useful. Saved for later This saves me having to try using the search. Quote Link to comment Share on other sites More sharing options...
