LR NUT Posted June 30, 2013 Share Posted June 30, 2013 Thinking of getting a performance filter for the hippo. The one that you keep for life more or less and have to clean. Question is does it make your car breath better? Anyone noticed the results? What would you clean the filter with..... Thanks folks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 30, 2013 Share Posted June 30, 2013 Don't bother, the only way you can let your engine breath better with same filter area is allow larger particles through which then reward any perceived gain by making your engine wear at 3 times the rate. Not a jaded view honest! Quote Link to comment Share on other sites More sharing options...
LR NUT Posted June 30, 2013 Author Share Posted June 30, 2013 Thanks Bowie69 (y) deffo off the wish list now! Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 1, 2013 Share Posted July 1, 2013 Bigger issue with TD4 is it has a hotwire type airflow meter which, if the various TD5 stories on here are any guide, does not like being coated in a fine mist of oil from the air filter. Quote Link to comment Share on other sites More sharing options...
