Baz2236 Posted July 3, 2013 Share Posted July 3, 2013 Hi can someone help me out please I want to relocate my battery the the rear of the cab so I can fit some after market seats. I brought some supposed ti be 800 jump leads and wired them up and get my battery in the back. But it struggles to turn over and the leads get hot. I am guessing these are not 800 amp leads can someone tell me what size cable I need and if you know where to get it from please. Baz Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 3, 2013 Share Posted July 3, 2013 Get yourself on ebay and buy some 35 or 50mm welding cable. Do the jumpleads have a cable size printed on them? Sometimes it will be written on the cable itself? How long is the run? If the battery is inside the cabin, it should be mounted in a sealed box, and vented to outside. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 3, 2013 Share Posted July 3, 2013 Actually, the stock cable is 40mm (on a TD5) according to the wiring diagram, so go with the 50mm. You'll need proper BIG crimpers to make off the ends. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 3, 2013 Share Posted July 3, 2013 Can I squeeze a question in here .... Is the mm size the CSA of the cable ? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 3, 2013 Share Posted July 3, 2013 ye Quote Link to comment Share on other sites More sharing options...
