Is summat amiss or am i jumping the gun?
Bingy
Maybe im too cautious
Yes I am beginning to think so, you shouldn't really let it idle at all with a new cam in it, you can scrap it quite quickly if you don't follow the running in procedure.
Trying to remember the oil ways in a V8, but one will get oil before the other for sure. I honestly think bring it up to 2500 and hold it for a while and it will get better, I know mine have done this for me after rebuild. It sounds quite sweet in all honesty, hard to hear it is misfiring....
when i started the engine, strangeley it only ran on 4 cylinders from one set of coils
i swapped the coil for the other and strangeley it was the same cylionders firing and not the opposite ones
ruling out the coils.
So, very basic question: Have you got +12v to the plug for the non-working coil bank?
Yes
I have also had the noid tester flashing away on the cylinders and also the inline led spark testers.
But as Mr Noisy has pionted out, are they doing it at the right time?
How do i check this out?
Get the cam run in and then worry about it, then you won't scrap the cam and followers and have to pull it all apart again.
To check they are firing in the right order, you just need to check your wiring in all honesty, ABCD from the EDIS and the associated plug numbers 6&1, 8&5, 4&7, 2&3.
Once you have the cam run in you can check the timing properly with a gun pointing at the pulley/timing marks and connected to either plug lead #1 or #6.
As long as you have the ABCD and plug wires in the right place, it will be fine.
The injectors are just bank fired (4 or even all 8 at once depending on setting) so they will make precious little difference to the running as 3 of the 4 are squirting at the back of a valve anyways.
  • 1 month later...
Next installment....
Finally got the inlets etc back from porting nice work
all put back on. All megasqiurt wiring back on
Then i realized.
Staring me in the face, despite looking, looking, looking and more looking.
Maybe i am getting mixed up with work,welders etc, thinking about settings too much.
ABCD, ABCD, ABCD, ABCD not errr.........ABDC! :angry2:
(Yes i am THE richard head)
Turned key.
Cough splutter
Turned key again............Bingo!
All 8 firing as should
https://www.youtube.com/watch?v=jrfcfCzCsC0
Quickly upto 3000-3500rpm
Ran spot on for a good 5 mins then oil hose blew off cooler.
So stopped straight away.
But I can now get two new ones made up from my local supplier this week
as these are standard ones chopped about to fit.
But BIG thanks for your patience!
I'll be back once ive fit the new hoses and
Once ive done another 25 mins @ 3000 next weekend hopefully :i-m_so_happy:
Music to my ears :D
Thanks again
Cheers lads
Yes, a V8 sounds a lot Better than a V4
I was enjoying giving it some throttle listening to the engine @3000 revs
In advance what info do I need to post so you can have a look at?
