rudd86 Posted July 8, 2013 Share Posted July 8, 2013 As above for a defender. Got s td5 front axle to go on, need to know if my 200tdi prop shaft will fit with this setup. Thanks Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 8, 2013 Share Posted July 8, 2013 no they are not, but in your case, you want to be retaining the 200tdi prop as its the vehicle/transferbox location that sets the prop length. Quote Link to comment Share on other sites More sharing options...
Bushpig110 Posted July 8, 2013 Share Posted July 8, 2013 No TD5 and 300 TDi are the same on Defenders, A Discovery 2 prop will fit a defender just change the output flange, or if your broke and the front prop on your Disco 2 falls off fit a defender TD5 prop and output flange it works fine ............ 200 TDi are different Quote Link to comment Share on other sites More sharing options...
Bushpig110 Posted July 8, 2013 Share Posted July 8, 2013 You'll need the radius arms for the later axles but it will all fit Quote Link to comment Share on other sites More sharing options...
rudd86 Posted July 8, 2013 Author Share Posted July 8, 2013 Its got the radius arms with the axle. So the prop I have on it bow will do. Brill Quote Link to comment Share on other sites More sharing options...
