DC_
Constant deep "clicking" noise on turning from front wheels.
Before resorting to my local grease monkey, and after checking bearings, I thought I would post here to see what your thoughts are.
RRC 1992 Auto V8.
Has just, in the last few weeks started clicking clunking from the front wheels when I emerge from the drive or anywhere else when i turn left or right. It doesn't seem to do it when straight.
Wheel bearings ok..... Loose brake pad on drivers side sorted after discovering a sticky piston (well hopefully sorted) so now after two and a half years of not being allowed in our forests, we are allowed with supervision, back in..... I have 12 days to sort this. :-(
Rang my good grease monkey and he reckons it could be wear in the swivel? I have noticed a very small leak of EP90 from the seal at the swivel and was thinking to replace with one shot....
Don't think we've ever had 2 weeks of 30 degree heat in Scotland so was thinking this may thin everything down and leaked more than norm?
Help is appreciated guys!
Share this post
Link to post
CV joint(s), classic symptoms IMHO.
Share this post
Link to post
Yup. CVs. Typically a pretty solid repeated 'clack', when there's some lock on, often worse in reverse. Swivels don't normally make a repeating noise.
Share this post
Link to post
Nuts !! (For want of a better word)
CV's easily enough to replace? I've had a look through the manuals, "Les" does a write up for replacing the full swivel (challis), but I can't remember seeing CV's being referred to.
Not got time just now to search the tinternet, I seen CV's on JGS4x4 at £27 each. Do I need any seals/gaskets? Sorry never done CV's before
Thanks for the comments so far.
Share this post
Link to post
Check your centre diff is ok, if not the new ones will be as bad in a couple of months.I got though two sets before finding the cause.
Share this post
Link to post
Caliper off, drive member off, wheel bearing out, hub off, stub axle off (catch all the one-shot in a bucket), pull out shaft, whack CV with a mallet to get it off the shaft, whack new CV into place, refitting is opposite... etc :)
Checking the old CV is easy, there shouldn't be any rotational play in it, check with it at an angle as well. You can disassemble them and wiping them out you will most likely see pitting on the balls and inside the cup, and the 6-legged spider thingy in the middle (forget the real name!)
You'll need at a minimum stub axle gasket, one-shot, wheel bearing grease, ideally a hub seal in case you nick it, and wheel bearing lock washers if they are junk. Drive member on the RRC seem to always be stuck on with RTV (silicone).
Re-seat the ABS sensor after, as when removing the CV it can knock it up quite easily.
Share this post
Link to post
Lunch break and time to reply,
Thanks for the info guys, will try source where to get the CV's and gaskets and shipped pronto sharp!! 12 days to get this done..... I've got bearing grease, one shot, locking washers and I'm sure a hub seal too in my spares.
Do I need RTV? (just order it with CV's?)
ABS sensors scare me so I'll be very carefull round about that.
As this is the first drive and I REALLY don't want to miss it, I'm worried that due to time I might struggle. If I were to make sure it's got plenty of one shot, would I be able to get through the drive (two days) or would this cause even more damage?
Thanks again, need to run as my Learners are wanting their driving lessons ;-)
Share this post
Link to post
Just one other thought, it would be worth checking your viscous coupling, as I have had that produce some clicking sounds before.
Jack up one front wheel, handbrake on, transfer box in neutral, put a breaker bar on one of the front wheel nuts and stand on it, it should move, very slowly. If it doesn't, it's lunched.... :(
Share this post
Link to post
Viscous good thanks for tip
Grease monkey says "sounds very dry"
Took some pics and the one that's clicking was almost bone dry.
In one of the pics you can see condensation on the swivel housing.
975796FC-3C06-487E-8ABB-E01BF1A054E1-689
A75DF24F-4521-46EB-AA21-CEDBAAAC0D05-689
D1058C42-6174-4957-941C-C3E244F525E8-689
Share this post
Link to post
Oh dear.... looks like you are stripping it then I guess?
Share this post
Link to post
Ideally if I had more time and feeling a bit more confident I would.
As my good mechanic can't squeeze me in before the drive, he told me to load it with one shot and do it as soon as you get back before heading out again.
I am praying this will be ok? Took it out after loading it up with one shot and it is quieter.
I am very tempted to order the CV and gaskets needed and do this one side before I go. I've got this weekend.
Share this post
Link to post
fill with grease and in use don't put the power on when on lock , it'll be fine I'd
say . And do check that VC if they lock up the cv's or axle diff are usually the
first sign
have a good drive and post up pics then get it checked out properly if you are not
confident , but with good basic tools and axle stand(s) you can do it in a day
cheers
Steveb
Share this post
Link to post
VC checked out doing the simple test.
Now filled with fresh one shot grease on both sides.
Will not apply power (much) on full turn.
Good amount of tools and axle stands I have (if not it'll give an excuse to put in my Xmas order)
So I have the camera at the ready :)
Share this post
Link to post
Well all went well and the "clicking" has gone. Not sure if it was due to having barely no EP90 in it or grease, but its done the trick. Will still order the parts and get the CV's done ASAP.
Here's a few sample pics of the weekend.
7C218B31-F316-4EE2-8E26-5D45139E45DF-683
A238B6F9-31F5-4570-8FBD-33E30FCE8D4B-683
C3E47837-BFEE-4B3A-963C-6A0234B3790C-683
4E5FB820-D5F5-494B-8EFA-D67ED4D1F17D-683
D3889FF5-EF11-445F-82F6-D2DA92C44F31-683
7E8F1908-A33E-4695-8E13-1AFA4EB468D0-683
Share this post
Link to post
Looks like you had a good weekend , got any more pics ?
good to hear its all gone quiet
cheers
Steveb
Share this post
Link to post
0DA84A73-9855-4EB0-BD2A-57BA38D02989-683
And one of thee most stunning views I know of
AC88F0B4-60B2-45EC-9C31-45E0D93BB78A-683
Homeward bound
D03742F8-38FA-4B1A-91F0-58D7EACF5942-683
Share this post
Link to post
I had worn CVs that clicked years ago. I replaced them with Britpart ones and was surprised that the did 90,000 miles bfore one of them let go and clicked badly. The bell cracked through in two places all the way through - you could see daylight through the cracks. The cause remains unknown, but the other side was perfect with no apparent wear. CVs are one component that Britpart do well, and at just over £30, at a very good price. Even shcroft Transmissions rate them highly, with BP CVs coming second best in destructive testing, outperformed only by a Gucci aftermarket, very expensive uprated alternative.
While avoiding high throttle positions may nurse the CVs a little, it's tight cornering and off roading that will kill them - cornering will reuire the viscous coupling to slip, and you've seen how much torque needs to be applied to it through the diffs and cv joints for that to happen, and off roading will shock load them as the wheels slip or spin and then find grip.
Share this post
Link to post
Thanks for the info snagger :-)
Share this post
Link to post
What size tyres have you got on your RR? Look like Insa Turbo Special Tracks.
My Colway Mud Terrain remoulds have done 6 years and getting "tired"....
Share this post
Link to post
265/75/16 DrRob.......
They are phenomenal ...... Doot doo do doo do.........
Share this post
Link to post
