02920al Posted July 29, 2013 Share Posted July 29, 2013 Hi, my 05 freelander td4 has the traction control warning lights coming on quite a lot at the moment. Sometimes on then straight off sometimes on and stays on. Any ideas? Thanks!!!! Quote Link to comment Share on other sites More sharing options...
EggNChips Posted July 30, 2013 Share Posted July 30, 2013 When the light is on, try pressing the footbrake and releasing. If it goes out then it's probably the brake pedal switch. Quote Link to comment Share on other sites More sharing options...
Adeyt Posted October 19, 2013 Share Posted October 19, 2013 I just bought a freelander Td4 and after going through some deep standing water following a deluge both the TC amber light and hill descent amber came on after a few moles and stayed on . Could the water be the cause ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 21, 2013 Share Posted October 21, 2013 The ABS/ETC/HDC lights are a common issue, if you read back through the freelander forum you'll find several previous threads on the topic. From memory, common culprits include: The switch on the gearstick ABS sensor Brake pedal switch ABS ECU (£££ so last resort) Quote Link to comment Share on other sites More sharing options...
02920al Posted November 10, 2013 Author Share Posted November 10, 2013 think mine was the switch as it seems to have stopped now......... until next time!! Quote Link to comment Share on other sites More sharing options...
