Tanuki Posted August 7, 2013 Share Posted August 7, 2013 I've always been a fan of Plus-Gas: when that's not available I'll mix up a brew of 50% Diesel and 50% Kerosene - which is dirt-cheap so you can afford to splash-it-on-all-over every six hours for a couple of weeks so it gets to really soak-in well. This mix poured down the spark-plug-hole and used to fill the sump managed to free-off the piston in an old Lister 'D' that had sat in a hedge for decades with the bore full of water. A bit of 2400 wet-and-dry on the bore once we got the piston out, a new set of rings - and it ran beautifully. If a couple of weeks of regular anointing with this brew won't free-off things then it's time for the Fire-Axe and the Big-Scary-Air-Hammer. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 9, 2013 Share Posted August 9, 2013 You can buy Plus Gas in 5l tins - eg from Lawson-his, K Supplies. I then decant it into used household spraying containers, where you can get a jet rather than a spray. I used to buy aerosols, but with the scale of the problem (ie Land Rovers) bulk is the way to go. Quote Link to comment Share on other sites More sharing options...
