Soren Frimodt Posted May 29, 2018 Author Share Posted May 29, 2018 Wheels arrived today and the tyres were popped on, suits the car much better. 8cm's narrower on the outside means they don't stick out as much making the axles look ridiculously wide. The tyres won't fall off as easy when offroading and dirt won't work its way in between the wheel and tyre as much. So overall a huge benefit, also they look better in Silver on this thing 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 29, 2018 Share Posted May 29, 2018 I'm really not a fan of mods, but they look great on there Sören Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted May 30, 2018 Author Share Posted May 30, 2018 10 hours ago, landroversforever said: I'm really not a fan of mods, but they look great on there Sören Neither am I.. And I had high hopes that I could use my Wolfrace's on these tyres but it would require 60mm spacers! So modulars are nice and cheap, and atleast the Silver suits the car Just can't wait to get out and test this thing in anger! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted June 3, 2018 Author Share Posted June 3, 2018 A bit was one today. Steering damper fitted with homemade bracket at the diff to tuck it up nice and high: The regs for the events I want to run nest year requires brakes at all 4 wheels as they are a bit 'speedy' so out came the old drumbrakes that were once fitted to the Sal's: Had it out for a little posing the other day: 2 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 4, 2018 Share Posted June 4, 2018 12 hours ago, Soren Frimodt said: A bit was one today. Steering damper fitted with homemade bracket at the diff to tuck it up nice and high: The regs for the events I want to run nest year requires brakes at all 4 wheels as they are a bit 'speedy' so out came the old drumbrakes that were once fitted to the Sal's: Had it out for a little posing the other day: did you only have brakes on the front wheels? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted June 4, 2018 Author Share Posted June 4, 2018 1 hour ago, RedLineMike said: did you only have brakes on the front wheels? No, I can see how you mimght think sp though I have a "pinion brake" on the back, located at the gearbox where the handbrake assy used to be. A hydraulic disc brake setup using a single RRC rear caliper. Works plenty well with the gearing through the driveline and you save heaps of weight (especially unsprung) BUT seeing as the speed has increased on their events (along with tyre size and HP) they've decided that it needs to have brakes on all 4 corners Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted June 6, 2018 Author Share Posted June 6, 2018 "Mirror, mirror on the wall" Sitting as far inboards as you do in this, its impossible to see anything just by turning your head (also the top of the seats are pretty wide, blocking the view) So I had hoped that a single mirror in the center would be enough. BUT some jerk has placed the spare-wheel right smack in the middle just because he thought it looked 'Racey' Alas, some more mirrors were required, and I do think it turned out alright, pretty well hidden away and quite protected. Time will tell if it works out: Barely noticeable from the front: And finally the view from the drivers seat: 3 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted June 8, 2018 Author Share Posted June 8, 2018 Oldschool 88" vs Newschool 88", which will win? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 8, 2018 Share Posted June 8, 2018 In terms of sheer good looks, the Series hands down 1 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted June 29, 2018 Author Share Posted June 29, 2018 Well thankfully a project is never done Decided to make winch tray in the back only a week before leaving for 3 weeks of offroading Don't even have a winch to put in there, but might snatch the Warrior off of the 88" Who would've known a Series Drop-plate is perfect for the job? 1 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 1, 2018 Author Share Posted July 1, 2018 So then, got it all finished up: Protrudes a little bit at the back, but I think it'll be alright: And finally I wasn't pleased with my placement of the waffleboards, made the rear look boring.. So they moved onto the roof instead: Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 2, 2018 Share Posted July 2, 2018 You'll regret that when you have to lift waffle boards filled with clay onto the roof Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 2, 2018 Author Share Posted July 2, 2018 58 minutes ago, elbekko said: You'll regret that when you have to lift waffle boards filled with clay onto the roof Haha not my problem, thats what you have a winch-bitch for right? 😎 Quote Link to comment Share on other sites More sharing options...
toenden Posted July 2, 2018 Share Posted July 2, 2018 3 hours ago, Soren Frimodt said: Haha not my problem, thats what you have a winch-bitch for right? 😎 ...so you will be the one getting the clay down your neck then... 😅 /mads Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 2, 2018 Author Share Posted July 2, 2018 23 minutes ago, toenden said: ...so you will be the one getting the clay down your neck then... 😅 /mads Nahh I'll stay covered under the roof Besides if we're driving in stuff so muddy that it'll fil up the waffles chances are I'm already covered in it myself anyways Since when have getting dirty become a problem in 4x4 competitions? I must've been living under a rock 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 2, 2018 Share Posted July 2, 2018 5 hours ago, Soren Frimodt said: Haha not my problem, thats what you have a winch-bitch for right? 😎 Well, I was speaking as former winch-bitch 1 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 12, 2018 Author Share Posted July 12, 2018 So far testing is going according to plan, VERY capable machine and easy to drive. Throwout bearing died om me, so the rearwinch was God-sent: Quote Link to comment Share on other sites More sharing options...
steve b Posted July 13, 2018 Share Posted July 13, 2018 Some top class bush engineering there Soren cheers Steve b Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 13, 2018 Share Posted July 13, 2018 That's brilliant! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 13, 2018 Author Share Posted July 13, 2018 Thnx guys, just realized i had vid of the gearbox crane in action as well 😁 VID_20180712_080137.mp4 Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 13, 2018 Author Share Posted July 13, 2018 Quote Link to comment Share on other sites More sharing options...
deep Posted July 13, 2018 Share Posted July 13, 2018 Oops! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted July 14, 2018 Author Share Posted July 14, 2018 Yeah who knew 37's on 6psi and a frontlocker would be hard on a stock CV? 😂 1 Quote Link to comment Share on other sites More sharing options...
deep Posted July 14, 2018 Share Posted July 14, 2018 We all do now. Thanks for doing the research on our behalf! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 14, 2018 Share Posted July 14, 2018 Did it make a good bang or just a boring crunch? Quote Link to comment Share on other sites More sharing options...
