Les Brock Posted October 3, 2006 Share Posted October 3, 2006 some thin wall ally tube approx 500mm long of...... 12.7 mm diameter 1.0mm wall 10.5 mm bore and 3.2 mm diameter 0.7 mm wall 1.8 mm bore or in old style 1/2" diameter 1/8" diameter measured as best an electrics person can measure with a digi vernier No its not for a cage Need to extend the ATL sender tubes for the fuel tank, and a new one is £120...all for a bit of tube.... so it's worth a punt to see if I can get some Quote Link to comment Share on other sites More sharing options...
02GF74 Posted October 3, 2006 Share Posted October 3, 2006 some thin wall ally tube approx 500mm long of......12.7 mm diameter 1.0mm wall 10.5 mm bore and 3.2 mm diameter 0.7 mm wall 1.8 mm bore or in old style 1/2" diameter 1/8" diameter does it have to be excatly that size? could you not make an adapter since B&Q sell aluminium tube in 1 m for smaller diameters and in 2 m lengths for larger diameters. From memory it comes in 2 mm increments, starting at around 4 mm and covers the sizes you are after(brass tube, again in metric sizes, is available from 2 mm O.D. up to about 6 mm). Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 3, 2006 Share Posted October 3, 2006 for the small stuff i'd try a modellers shop. or machine some up dependin how long u want it Quote Link to comment Share on other sites More sharing options...
dollythelw Posted October 3, 2006 Share Posted October 3, 2006 B&Q Quote Link to comment Share on other sites More sharing options...
Les Brock Posted October 3, 2006 Author Share Posted October 3, 2006 Ta all B&Q don't do it small enough...local model shop is pants got it from here http://www.sussex-model-centre.co.uk/shopexd.asp?id=5083 Quote Link to comment Share on other sites More sharing options...
simonr Posted October 4, 2006 Share Posted October 4, 2006 Ta all B&Q don't do it small enough...local model shop is pants got it from here http://www.sussex-model-centre.co.uk/shopexd.asp?id=5083 I was going to suggest SMC but you clearly found it on your own! - they are pretty good for that kind of thing! Si Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted October 4, 2006 Share Posted October 4, 2006 You might try Andy at Allisport as he's not too far from you, may well have an off cut. Quote Link to comment Share on other sites More sharing options...
