Mean Green Posted August 24, 2013 Share Posted August 24, 2013 Other than the knocking - are there any other symptoms of Big End wear? I have a very similar knock on my 200tdi. I have not worked through all the checks on lump pump, vac pump etc etc but wondering if I can narrow it down any further? It drives fine, with plenty of power. The only other 2 issues that may or may not be related are 1. the battery light does not go out when idling, even with little load and it only when it gets its 1st rev that is goes out 2. I get a fairly big puff of smoke on start-up - especially if it has been sitting overnight or a few days - it is not a definate white or blue or black smoke more a blue-ish grey could either of these be related or am I just getting paranoid? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 24, 2013 Share Posted August 24, 2013 Horrible knock, having heard the video. Scared my dogs and they are used to 300tdis. Stupid thought perhaps, (but that's me), if the bearings were replaced so recently and have got in such a state so soon is it possible they were not the correct size? Or maybe there is an oil pump problem? Quote Link to comment Share on other sites More sharing options...
jackmac Posted August 24, 2013 Author Share Posted August 24, 2013 Horrible knock, having heard the video. Scared my dogs and they are used to 300tdis. Stupid thought perhaps, (but that's me), if the bearings were replaced so recently and have got in such a state so soon is it possible they were not the correct size? Or maybe there is an oil pump problem? I think they were not torqued correctly, and not installed cleanly which combined has caused excessive wear. I have put in standard size shells because that is what came out, but I hadn't even considered that those might have been wrong! Unfortunately, rain prevented play today so I won't know until tomorrow if I've fixed it. Quote Link to comment Share on other sites More sharing options...
steve b Posted August 24, 2013 Share Posted August 24, 2013 Did you do a test fit with plastigage to check the clearance? I guess you will know what its like when you run it up as you say cheers Steveb Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 24, 2013 Share Posted August 24, 2013 They very probably are standard, I'm just being alarmist. If they weren't torqued that would cause all sorts of problems. You are lucky it didn't do a lot of damage. Quote Link to comment Share on other sites More sharing options...
western Posted August 24, 2013 Share Posted August 24, 2013 if they are anything but standard, on the non working side they will be marked, .010 or .020 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2013 Share Posted August 24, 2013 TBH, I think you have found the problem -loose nuts, bolt it all back together and fingers crossed If not, then as you say it is head off time. Quote Link to comment Share on other sites More sharing options...
jackmac Posted August 26, 2013 Author Share Posted August 26, 2013 Fixed! I think it must have been the big ends not being torqued up Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 26, 2013 Share Posted August 26, 2013 Fixed! I think it must have been the big ends not being torqued up You were blooming lucky then, could have written off the engine if you hadn't caught it in time. Quote Link to comment Share on other sites More sharing options...
Mutz Posted August 26, 2013 Share Posted August 26, 2013 Need another vid on what it sounds like now lol well done Quote Link to comment Share on other sites More sharing options...
western Posted August 26, 2013 Share Posted August 26, 2013 Fixed! I think it must have been the big ends not being torqued up well found, lets hope the engine gives you many miles of good service. Quote Link to comment Share on other sites More sharing options...
jackmac Posted August 26, 2013 Author Share Posted August 26, 2013 Need another vid on what it sounds like now lol well done Ignore the rattle at the start, that's the exhaust due to the flange bolts on the centre pipe exiting somewhere up the road last week!Interestingly, when I bought the truck I could barely turn the crank with a large breaker bar with the glow plugs out, sometimes needed an extension bar. I can now turn it over with a ratchet when there is no compression (just about) so might pick up a bit more power too! Thanks to everyone for their help and advice, looking forward to getting her back on the road Quote Link to comment Share on other sites More sharing options...
western Posted August 26, 2013 Share Posted August 26, 2013 sounds much healthier Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 26, 2013 Share Posted August 26, 2013 Sounds like a tractor, so I guess that's a job well done Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted August 27, 2013 Share Posted August 27, 2013 Hang on Bowie, lemme get that for you! Sounds like a perfectly healthy devil spawn, so I guess that's a job well done No but seriously, that's a really good outcome. Especially from what it used to sound like! Quote Link to comment Share on other sites More sharing options...
Mutz Posted August 28, 2013 Share Posted August 28, 2013 sounds just like mine!!!! well done mate. Quote Link to comment Share on other sites More sharing options...
