ltwt1981 Posted September 7, 2005 Share Posted September 7, 2005 Anyone know off the top of your head or handy to measure, the thickness of a series front brake drum on the hub. I can measure it tonight but would like to know if possible before. Quote Link to comment Share on other sites More sharing options...
minivin Posted September 7, 2005 Share Posted September 7, 2005 I'm guessing 1/4" Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 7, 2005 Share Posted September 7, 2005 5, possibly 6mm tops Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 7, 2005 Author Share Posted September 7, 2005 Sounds about right to me. Where to get longer wheel studs then. Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 7, 2005 Share Posted September 7, 2005 can get them from zues, will u need them then? i did when i done my conversion Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 7, 2005 Author Share Posted September 7, 2005 I need to space off 15mm max, 5/6mm already with lack of brake drum is OK, but I need 10mm more. I could space off the rear of the hub a few mm I suppose. Would 5mm less be a problem on the studs then, I may have a look at it first. Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 7, 2005 Share Posted September 7, 2005 If you lose the drum and replace the thickness with a spacer you end up back at the standard thickness therefore the front studs will be fine as standard. If you want to space more than that you'll need the extended studs. Zeus do em but they're pricey!!!! £5 ish each IIRC......... Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 7, 2005 Share Posted September 7, 2005 + the vat Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 7, 2005 Author Share Posted September 7, 2005 I can get 16mm trailer studs in different lengths and quite reasonable will look at these, any thoughts on strength with 15mm spacers . I think it should be OK, I may machine screw the spacers back to the hub for more strength. Quote Link to comment Share on other sites More sharing options...
Tonk Posted September 7, 2005 Share Posted September 7, 2005 think i run 12mm spacers with no probs..... Quote Link to comment Share on other sites More sharing options...
