csimoes Posted November 14, 2013 Author Share Posted November 14, 2013 ok. Did the continuity test and it doesn´t buzz.......... so what's my solution to this problem????? wire it directly to the ECU? shouldn't the relay board be prepared for this type of option??? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2013 Share Posted November 14, 2013 ok. Did the continuity test and it doesn´t buzz.......... so what's my solution to this problem????? wire it directly to the ECU? shouldn't the relay board be prepared for this type of option??? The MS relay board is not the greatest layout ever, it does have some (small) pads for the SPR1-4 inputs so you can wire to those. Unfortunately MS's designers have to make a few compromises as the boards must be "all things to all people", and when they make a board, people think of some new feature which would be easier if the board was different somehow... Quote Link to comment Share on other sites More sharing options...
csimoes Posted November 14, 2013 Author Share Posted November 14, 2013 but my wire is connected to that pad for spr1 and the signal doesn't go through. what do you advice? connect the wire that comes from the LPG directly to pin 3 of the db37 on the ECU? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2013 Share Posted November 14, 2013 Just to be 100% sure, these pads? Quote Link to comment Share on other sites More sharing options...
csimoes Posted November 14, 2013 Author Share Posted November 14, 2013 no no no (lost in translation) my wire goes to the screwed thingy on the bottom. S1 i thought that was the spr1 connection!! Quote Link to comment Share on other sites More sharing options...
csimoes Posted November 14, 2013 Author Share Posted November 14, 2013 i just looked at Nige's installation manual and it doesn't say that S1 is for SPR1...... so the problem must be that.... Note to Nige: for dumb asses like myself, add a few more instructions about SPR connections on a Relay board Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 14, 2013 Share Posted November 14, 2013 10 4 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 14, 2013 Share Posted November 14, 2013 Sorry, Work is manic, been TIGin' for hours / days this week and have pegged diff orders coming out of my ears...... and I can only do one a day due to pre / post heating Aaaaargh ! and other running about......9 diffs to build up next week !!!!!!!!!!!!! ............ "Mummy ......." .............. Quote Link to comment Share on other sites More sharing options...
csimoes Posted November 14, 2013 Author Share Posted November 14, 2013 like i say to a friend that is a mecanic, don't complain about having stuff to do (££) that's a good sign well, tomorrow i'll be soldering wire to that SPR1 pad...... i'll report back, hopefully with everything working right Nige, i tried your spark table for LPG and boy did it sound good!!!!! went like a bat out of hell Quote Link to comment Share on other sites More sharing options...
csimoes Posted November 15, 2013 Author Share Posted November 15, 2013 Problem solved Everything is working perfect Thank's for all your help Quote Link to comment Share on other sites More sharing options...
