manxrover Posted September 15, 2013 Share Posted September 15, 2013 Hi all Got a real headache with my 2001 TD5, the horns and cruise control have stopped working, checked all connections to the horns an cruise control, both work when direct power is applied no vac leaks, changed rotary coupler in steering wheel, but still no joy. Has anyone ever had this problem as there seems to be a lot of threads on the web but no one has had a result. The only thing I can think of is the rotary coupler I got from Ebay may be duff, so I will try another one, but in the mean time anyone any ideas. Regards Brian Quote Link to comment Share on other sites More sharing options...
sierrafery Posted September 15, 2013 Share Posted September 15, 2013 check fuse F16 in engine bay(this feed is connected to the cruise controll switch too beside the horn relay) Quote Link to comment Share on other sites More sharing options...
manxrover Posted September 15, 2013 Author Share Posted September 15, 2013 Hi Thanks, Done that, and replaced both relays with new ones, shorted fuse 16 horns sound, shorted relay horns sound, but no power to horns from steering wheel buttons. (gasp) Thanks Brian Quote Link to comment Share on other sites More sharing options...
sierrafery Posted September 15, 2013 Share Posted September 15, 2013 then the rotary coupler becomes the most obvious... second hand are not reliable ... i know that a new one is friggin expensive ... though it's strange that only the horns and the cruise controll dont work with both coupligs ... bypass the rotary coupler on the horn circuit and try the buttons then to make sure... if it will not work this way there's some other issue... at the white plug (C0082) the purple/orange wire is for horns, connect the switch's output there and see if it works by pushing it Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted September 16, 2013 Share Posted September 16, 2013 I have never seen a vacuum unit for a TD5 cruise control, this is very interisting. Quote Link to comment Share on other sites More sharing options...
