S2A109RAG Posted September 22, 2013 Share Posted September 22, 2013 I have a Tired 3.5 V8 which has had an aftermarket cam installed 6 months ago.... Will this cam be a suitable replacement for a 3.9 V8 which I now have to replace the older 3.5 V8 unit? Both Engines are V belt. The 3.9 has had all new lifters and refreshed heads. ( Has not been run yet ) Quote Link to comment Share on other sites More sharing options...
zim Posted September 22, 2013 Share Posted September 22, 2013 What can was it ? Physically it will fit. I moved an aftermarket cam from my 3.5 which had very little use to my 4.2 G Quote Link to comment Share on other sites More sharing options...
Fatboy Posted September 22, 2013 Share Posted September 22, 2013 It will fit but is it still I n perfect condition? When it was fitted to the 3.5, we're new lifters fitted and it properly bedded in. Was the engine oil system in good condition or could the cam have suffered from insufficient oil? For me, if you've gone that far in and are renewing everything else, I'd renew the cam too. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted September 22, 2013 Share Posted September 22, 2013 Not a good idea.....not ideal as mentioned above. Camshafts don't like to be moved around, they wear very specific and if that changes they can accelerate in the wear department much easier. If you really want to do this, was the aftermarket cam fitted with new lifters and run in the proper way in the 3.5, if yes change it over but mark every follower and put it in the exact spot it was, so what am did you fit to the 3.5 and who was the supplier? Quote Link to comment Share on other sites More sharing options...
