DrRob Posted October 2, 2013 Share Posted October 2, 2013 Looking to swap this out for a new one. Anybody know if you need to drain the sump first before removing it? Cheers PS Why are the breathers never leak proof? Mine seems to leak where the sump pipe joins it..... Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted October 2, 2013 Share Posted October 2, 2013 I presume this is a 200Tdi? The oil level in mine is above the end of the metal pipe so when you remove the hose it pushed oil of of the pipe. If you are quick enough with the swap you *should* be able to do it without using much oil. Just connect the new pipe to the breather and route it down to the pipe, unroute (is that a real word?) the old one but leave it connected then just quickly swap them over. Failing that, just drain into a clean bucket, swap it and just pour the oil straight back in the top. Quote Link to comment Share on other sites More sharing options...
DrRob Posted October 2, 2013 Author Share Posted October 2, 2013 Yep, 200Tdi. Cheers for the info. I thought that might be the case. Sump area a bit mucky down there so Gunk and jet wash being put into action pre-swap over.... I'm trying to get that side of the engive a bit cleaner hence new pipe and breather being fitted..... Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 2, 2013 Share Posted October 2, 2013 Interesting... might explain the pishing oil out of mine, I wonder if the pipe has perished and ahs now stopped keeping the oil in... Mav Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 2, 2013 Share Posted October 2, 2013 Don't know if anyone wants post a photo as I feel I am missing out on something here Quote Link to comment Share on other sites More sharing options...
DrRob Posted October 3, 2013 Author Share Posted October 3, 2013 Don't know if anyone wants post a photo as I feel I am missing out on something here You obviosuly have a nice oil leak free engine...... Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 3, 2013 Share Posted October 3, 2013 Unless you have broken yours, then don't bother replacing it - it's just hollow plastic. Clean it out with petrol. The hoses may need replacing, but not the plastic unit. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 3, 2013 Share Posted October 3, 2013 You obviosuly have a nice oil leak free engine...... I wish but mine seems to be coming from just about every possible gasket or seal, after it has been fully degreased I will know more of where the oil is coming from but too much other stuff to be getting along with before I get to that point. Quote Link to comment Share on other sites More sharing options...
