P38 Paul Posted October 7, 2013 Share Posted October 7, 2013 hi there , can anyone advise me on a gearbox problem that i have ? when i used to start the car from hot or cold , the engine will slow down for a split second when i selected a gear & then run ok which i would of said was normal , but recently when i select a gear it slows down so far that it sometimes stalls , i did'nt think you could stall an automatic . has anyone had the same problem ? any ideas would be a great help , cheers , Paul . Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 7, 2013 Share Posted October 7, 2013 Not heard that one before. Try giving Ashcrofts a call. Usually very helpful. Quote Link to comment Share on other sites More sharing options...
poohbear Posted October 7, 2013 Share Posted October 7, 2013 It could be an idle problem rather than gearbox - does a similar thing happen when you load the engine up with heated screen, seats aircon etc? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 7, 2013 Share Posted October 7, 2013 Diesel/V8? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted October 8, 2013 Author Share Posted October 8, 2013 hi people , the car is a p38 diesel , also there is no noticable change when the engine is loaded , & the car drives as it should with very smooth gear changes in both hi & low ratio . its just from neutral to drive or neutral to reverse that the engine shudders the revs drop & sometime stalls . it sound like it needs an adjustment to stop the drag to me , can these gear boxes be adjusted at all ? thanks for all the usefull advise & any more advise that you can give me . Paul . Quote Link to comment Share on other sites More sharing options...
elbekko Posted October 9, 2013 Share Posted October 9, 2013 Sounds more like the engine can't keep the idle up, I'd guess the injection pump to be the culprit, but could as well be a sensor. Quote Link to comment Share on other sites More sharing options...
