Anderzander Posted October 11, 2013 Share Posted October 11, 2013 I picked up one of those stainless catering bench. It's makes a really nice surface for clean work. It would have been nice to have a heavy duty one to mount my vise to - but I didn't have space for both, so I fitted my vise to an ikea stool, which has proved very stable and useful for being lower and movable. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted October 11, 2013 Share Posted October 11, 2013 I find no matter what size the workbench is will soon get just about everything chucked on there....... leaving you with a 500x500mm working space Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 11, 2013 Share Posted October 11, 2013 ....leaving you with a 500x500mm working space 500x500mm? You don't know 'ow lucky you are! In my day ....... Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted October 11, 2013 Share Posted October 11, 2013 2ft deep is perfect for what i have ever needed with a shelf above that thats 1ft deep and 14ft( about 5ft working space and 9ft random stuff) Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted October 11, 2013 Share Posted October 11, 2013 8' x 4' 1" ply on a steel frame here and I still end up working in a 18" square space surrounded by junk. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 11, 2013 Author Share Posted October 11, 2013 Ross as you and I are similar height I would strongly recommend a 1m high bench everyone I know hates it but then there all short arse's. Mike Having had a measure of my workbench at work, I'm going to go with the ~1m High. My bench at work is a bit on the low side!! As for depth, need to get the tape out in the workshop but 2.5' deep seems like a good balance for me with my height and long arms. Quote Link to comment Share on other sites More sharing options...
muddy Posted October 13, 2013 Share Posted October 13, 2013 Whatever you make sure there's at least a 4x2 or angle iron frame under the vice area and it's bolted to the wall and floor, I'm probably teaching you to suck eggs but spraying the contents of bench and vice across the shop when you were stood on a length of scaffold tube 3' up isn't much fun. Will. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 13, 2013 Author Share Posted October 13, 2013 Whatever you make sure there's at least a 4x2 or angle iron frame under the vice area and it's bolted to the wall and floor, I'm probably teaching you to suck eggs but spraying the contents of bench and vice across the shop when you were stood on a length of scaffold tube 3' up isn't much fun. Will. That's the plan, Build it into the space as I go . Will have some supports directly below the vice. Quote Link to comment Share on other sites More sharing options...
discomikey Posted October 17, 2013 Share Posted October 17, 2013 here at terex we have some service cart on steroids type things, along with workbenches, beefy steel and about 4ft by 2ft theyre ideal as mobile benches for assembly and dissasembly of backhoes. easy to keep all your other carp off and keep clean. the benches are hardly ever used as a result too which keeps them clear Quote Link to comment Share on other sites More sharing options...
yalan Posted October 20, 2013 Share Posted October 20, 2013 I spent a long time planning mine & ended up 2ft deep and 42" high. I'm 6'1" and love it for working height. Quote Link to comment Share on other sites More sharing options...
