TD5 wont rev when clutch depressed
Anf
Took my 52 plate TD5 Defender for MOT recently. Whilst at local garage engine light came on - cleared this but then engine would not rev. Got them to replace the switch on the clutch master cylinder but problem persists! Any clues would be much appreciated Thanks Andy
The clutch switch is on the master-cylinder: it switches between two fuel-profiles. One [active when the clutch pedal is pressed] shuts the fuel off pretty much immediately you close the throttle - so the revs drop rapidly for gearchanges. The second profile - active during normal driving - gives a slower defuelling if the throttle's shut quickly - reducing shock-loads on the driveline. It can also potentially avoid breaking traction if you snap the throttle shut under marginal-grip conditions.
It also controls anti-stall programming - the behaviour of the engine if you try and load the engine without applying any throttle (like when reversing a trailer and just wanting to creep along).
Rather a good idea, actually!
As to the particular issue being reported on here, I'd look at the throttle-pot and associated wiring first, then get the codes read.
  • Like 1
