EFI to Carbs Conversion
Johannadine
could it be doing this because the Oxygen sensors are out? :unsure: soooo stressed :(
You need the O2 sensors for the ECU to work correctly, without them the ECU just uses a preset figure as a get you home mode, first thing to do there.
And I would double check by unplugging and plugging back in the MAF sensor as to double check the security of connection.
