mcc1979ian Posted October 26, 2013 Share Posted October 26, 2013 Ok so last night i was out in the garage and went to use my compressorso i turns it on as per usual, lets it build up, then stops as usual once up to pressure. Once i started using it the pressure suddenly drops and theres a sound like air has just rushed through the tank then i left with very little pressure as the motor dosent kick back in straight away. Any ideas fellas? Quote Link to comment Share on other sites More sharing options...
tidoh2012 Posted November 1, 2013 Share Posted November 1, 2013 sounds like pressure switch/relief valve to me Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted November 4, 2013 Author Share Posted November 4, 2013 Ok thanks, do you know if the valve can be cleaned or is it a replace job? Quote Link to comment Share on other sites More sharing options...
tidoh2012 Posted November 7, 2013 Share Posted November 7, 2013 not sure but I should think you can take it off and clean it.If not you can get switches and valves off ebay easily enough and they aren't too expensive Quote Link to comment Share on other sites More sharing options...
