spot light help from somebody wiring from main beam
hi all
currently have front spots on a relay controlled by switch on my dash
where is best to pinch the 12v signal from my main beams to take to the relay so they all work together as i want the switch for my rear work lamp
cheers
IIRC you're only allowed to use them when using full beam, so take the full beam feed from one or other. Can't remember the colours off the top of my head, they're in the haynes manual, its blue and something. Red or Orange spimgs to mind, think the main beam is white or grey.
