reggie Posted November 13, 2013 Share Posted November 13, 2013 A while back the rear window in the misses 3dr TD4 stopped working, it dropped down a little & when you try to put it up it just clicks & kinda makes a grinding noise. You can actually move it up & down with your hands. I need to get it sorted now winter is approaching & it's a bit of a security risk too. Any ideas what I might be facing when I strip the back door? Quote Link to comment Share on other sites More sharing options...
EggNChips Posted November 14, 2013 Share Posted November 14, 2013 Rear window regulator has snapped, either complete new regulator, which is quite expensive (~£150) or a repair kit, whcich is a little fiddly to fit (£20~) Quote Link to comment Share on other sites More sharing options...
reggie Posted November 14, 2013 Author Share Posted November 14, 2013 Is it normally just the cable that snaps or a motor fail? Thinking about it though, all the noise must be the motor so guessing it's just the cable. Do you just need a new cable or are there any plastic fixings that need replacing? Quote Link to comment Share on other sites More sharing options...
tim_roberts Posted November 14, 2013 Share Posted November 14, 2013 The repair kit should come with all the bits you need. I've not done a rear window, but I did the front passenger window a while back with a cheap kit from eBay - worked a treat, if a little fiddly to fit. Quote Link to comment Share on other sites More sharing options...
reggie Posted November 14, 2013 Author Share Posted November 14, 2013 Ok, I'm looking at a repair kit on eBay using a stainless cable. One of the other problems we had was that the window would not go down halfway, if you tried it would drop right down so it was either up fully or down fully. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2013 Share Posted November 14, 2013 The body control module decides what the rear window is allowed to do, there's some logic about not allowing it half open (perhaps above certain speeds, I've never figured it out). Your fault sounds like the cable's snapped, all the window regs in the FL do that, the repair kits are variable - some report miserable failure, mine's been fine. Mine came off ebay member "e-crofting" I think it was. Quote Link to comment Share on other sites More sharing options...
reggie Posted November 14, 2013 Author Share Posted November 14, 2013 Ahh fridge, that's the chap I've been speaking to on ebay "e-crofting" going to buy the cable from him as it sounds good quality. Is it hard to do, or do you just need a bit of time & patience? As if I didn't have enough to do with trying to get my Range Rover back on the road Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 14, 2013 Share Posted November 14, 2013 Getting the cable off & on is the fiddle, remaking the cable is dead easy. If you take a deep breath and look closely at how the mechanism works, there are a couple of bits where you can cunningly apply a clip/clamp/mole grip to un-tension it or hold it to make life easier. I can't remember exactly, but I've still got the passenger side to do on mine... Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 15, 2013 Share Posted November 15, 2013 When you take the rear window out, remember to undo the terminals for the heated window.... On the motor housing, make sure you put the plastic, telescopic wire end piece back on with the same orientation or else the overload switch doesn't work. It's quite easy, just a little fiddly. Quote Link to comment Share on other sites More sharing options...
reggie Posted November 19, 2013 Author Share Posted November 19, 2013 Ok, well I got the panel of on Saturday & the cable has indeed snapped. Also just used her Freelander & the heated rear screen no longer works, when I asked the misses how long that has not been working she said since the window broke. Any ideas why this might be? Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 20, 2013 Share Posted November 20, 2013 Did it still have the two wires attached to the terminals on the bottom RH corner of the glass? If so, check that power is getting to them.. Quote Link to comment Share on other sites More sharing options...
reggie Posted November 23, 2013 Author Share Posted November 23, 2013 It did still have wires connected. Just looked at the switch & it doesn't click in when pressed so suspect the button has gone. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 25, 2013 Share Posted November 25, 2013 No, the button is a momentary type, the ECU controls the relay when you hit the button. Quote Link to comment Share on other sites More sharing options...
reggie Posted November 25, 2013 Author Share Posted November 25, 2013 No, the button is a momentary type, the ECU controls the relay when you hit the button. Ok, so possibly the relay gone then? Quote Link to comment Share on other sites More sharing options...
