gruntus Posted October 9, 2006 Share Posted October 9, 2006 Gents, I want to run braided fuel lines and possibly breather pipes throughout my 90 for long life (rather than bling ). Are they an arm and a leg and do you know of reasonable suppliers? Getting ready for the insults.... Cheers in advance G Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 9, 2006 Share Posted October 9, 2006 I fitted a braided petrol pipe to mine, the rubber liner rotted away within a couple of years. I believe there are different liner materials available, although I've found that rubber pipe marked "petrol" doesn't last five minutes. Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted October 9, 2006 Share Posted October 9, 2006 I believe there are different liner materials available, although I've found that rubber pipe marked "petrol" doesn't last five minutes. There are indeed different specs of hose.... The fuel hose isell is FIA stuff and is a synthetic rubber inner with the braid actually boded into ( 1/2 covering ) and onto ( full covering ) the inner. The cheapo stuff is a rubber hose with the braid stretched over it - about £6-9 a metre. Mine is about £24 a metre! I have done several rally / kit cars with braided fuel hose throughout though there is a better / cheaper way: Run solid 3/8 copper or aluminium pipes around the car and just use flexi joins either end of it to join to the filter / engine etc. ... Don't fart about with jubilee clips either - do the whole thing with threaded unions. It will cost you more but you will only have to do it once! David LLAMA 4x4 Our motorsport plumbing site New online store Quote Link to comment Share on other sites More sharing options...
02GF74 Posted October 9, 2006 Share Posted October 9, 2006 I have done several rally / kit cars with braided fuel hose throughout though there is a better / cheaper way: Run solid 3/8 copper or aluminium pipes around the car and just use flexi joins either end of it to join to the filter / engine etc. ... Don't fart about with jubilee clips either - do the whole thing with threaded unions. It will cost you more but you will only have to do it once! one word: B&Q microbore tubing - you can flare the ends using a brake pipe flaring tool or solder on an olive. On hte LWT, I am using braided hose ffrom VWP - been on there approx 4 years; no leaks as yet. Quote Link to comment Share on other sites More sharing options...
