Chris Davies Posted October 9, 2006 Share Posted October 9, 2006 Has anyone who has done this, putting a series 3 gearbox into a series 2 had a problem with the clutch slave cylinder touching the bellhousing cross member, it seems to rest fairly heavily on it. I don't have the engine in ATM, would this be causing the problem? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 9, 2006 Share Posted October 9, 2006 Remove the two reinforcing ribs then it will fit. Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 10, 2006 Share Posted October 10, 2006 chop the webs back before you fit the engine, its a PITA to cut them out after its all in situ Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted October 10, 2006 Author Share Posted October 10, 2006 chop the webs back before you fit the engine, its a PITA to cut them out after its all in situ Do I chop them both (front and rear) out completely or just 'scollop' them a bit? Should I remove the gearbox again? Might be worth giving it a go without removing it Thanks for the advice Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 10, 2006 Share Posted October 10, 2006 i chopped both of mine out, but i left about 20mm down the chassis side just for a bit of strength Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted October 10, 2006 Author Share Posted October 10, 2006 Thanks Tonk, off to do a bit of grinding Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 10, 2006 Share Posted October 10, 2006 i done mine with engine in place but box taken out, then i chopped the whole crossmember out at a later date to fit a different one but then engine and g/box were both in place Quote Link to comment Share on other sites More sharing options...
