bagpuss_993 Posted December 8, 2013 Author Share Posted December 8, 2013 Got a spare fuel temp sensor I, m going to adapt into a pressure fitting Quote Link to comment Share on other sites More sharing options...
bagpuss_993 Posted December 13, 2013 Author Share Posted December 13, 2013 Checked fuel pressure only got 1.5 bar, so will be taking pump out and sending back to bearmach for a replacement, Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 13, 2013 Share Posted December 13, 2013 Would you share the set up you used to test your fuel pressure ? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 13, 2013 Share Posted December 13, 2013 Got a spare fuel temp sensor I, m going to adapt into a pressure fitting did you run the purge procedure before that? ... depress the throttle 5 times consecutively, wait untill the MIL stops flashing and measure then. Quote Link to comment Share on other sites More sharing options...
bagpuss_993 Posted December 16, 2013 Author Share Posted December 16, 2013 Yep did the purge process twice before doing the test, but it did not hold the pressure when fuel pump switched off Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted December 17, 2013 Share Posted December 17, 2013 The fuel pressure is to low, and for now don't worry about CAN fault you red on your code reader. Did you renew the fuel filter and the micro filter while you were renewing the pump. Quote Link to comment Share on other sites More sharing options...
bagpuss_993 Posted January 5, 2014 Author Share Posted January 5, 2014 Hello all just a quick update ecu,s in and being tested, as soon as i got any news i will let you all know. Rangy35 i replaced the fuel filter as one of my non start checks, as for the micro filter no but have never heard of it to be honest or to its location, cheers guys all your help is very much appreciated, Rod Quote Link to comment Share on other sites More sharing options...
bear Posted January 9, 2014 Share Posted January 9, 2014 I think you'll find the micro filter is in the rear outermost outlet of the fuel filter block. Griff Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted January 10, 2014 Share Posted January 10, 2014 Yes that is correct for micro filter. Again the fuel pressure you tested was it the supply or the return pressure? Quote Link to comment Share on other sites More sharing options...
Charlesj Posted May 2, 2020 Share Posted May 2, 2020 I’d double check the hose order on the filter and the filter housing.. if the pump is new might have had connections reversed... passenger far side is the drain connecting to the front left connector of filter.. next is the high pressure to fuel reg at engine..low pressure to filter left hand side rear... Quote Link to comment Share on other sites More sharing options...
