jameshub Posted December 10, 2013 Share Posted December 10, 2013 Hi I just picked up a 1998 WOLF and whilst test driving it i had no problems with the clutch although it did seem a bit 2 stage (from floor to half way did nothing, then it strung into action)......i checked the clutch fluid and it was full but very darl brown so god knows how long that had been in there. anyway, on my drive back and when i got in to traffic i found that it started getting stuck on the floor when i used it and i had to put my toe under it to spring it back up.....not easy! I've now changed the fluid and its much better and doesn't have any 2 stage feeling any more, but it does feel like it still wants to get stuck, albeit not as much Any thoughts? Quote Link to comment Share on other sites More sharing options...
chris200100 Posted December 10, 2013 Share Posted December 10, 2013 Sounds like the clutch slave cylinder piston is starting to go through the clutch fork. It happened to my 300tdi 110 last year Quote Link to comment Share on other sites More sharing options...
jameshub Posted December 10, 2013 Author Share Posted December 10, 2013 Sounds like the clutch slave cylinder piston is starting to go through the clutch fork. It happened to my 300tdi 110 last year is that a big job? Quote Link to comment Share on other sites More sharing options...
jameshub Posted December 10, 2013 Author Share Posted December 10, 2013 Sounds like the clutch slave cylinder piston is starting to go through the clutch fork. It happened to my 300tdi 110 last year ignore that, i know its not a big job Quote Link to comment Share on other sites More sharing options...
