jackmac Posted December 10, 2013 Share Posted December 10, 2013 Quick question regarding wiring for my FIA switch. I know this is a topic that's been covered to death all over, but mine is a bit different. I am using the relay from an X-Charge system on the main battery cable, the trigger wire for this go through the FIA switch thus meaning I don't have to run 40mm^2 cables through my cubby box. I understand how to wire the switch, except for the resistor. I know one side of the 1st spade terminals goes to earth through a resistor to prevent damage to the alternator, but not sure where the +ve side for this needs to come from? Obviously I can't take a feed from the large terminal on the FIA switch because in my set up that's not actually the battery cable, so where does it need to come from? Do I take it from the -ve side of the X-Charge relay, or do I need to take it off the starter motor? Hope that makes sense... I'll knock up a diagram if not! Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted December 10, 2013 Share Posted December 10, 2013 It would need to connect to the vehicle side of your relay, or the starter or the alternator. Are those relays rated for the amount of current involved? Quote Link to comment Share on other sites More sharing options...
jackmac Posted December 10, 2013 Author Share Posted December 10, 2013 Yep, it's a 200A relay I think and the draw on it should never go above 100A. Winch is running through a much higher rated one that that. On the battery box I have a mechanical isolator which is the last thing before the battery cable connects to the starter motor, so I could put a wire from the engine side of that isolator then? Quote Link to comment Share on other sites More sharing options...
jackmac Posted December 10, 2013 Author Share Posted December 10, 2013 Urgh just read your post properly, I'll connect it directly to the relay. Thanks Quote Link to comment Share on other sites More sharing options...
