reddog Posted December 16, 2013 Share Posted December 16, 2013 HI there, I have just bought an 04 reg TD4 and the clutch pedal travel is causing me concern. You press the pedal down and about 60% of the travel is easy and doesn't take up the clutch, the last 40% is quite heavy and actuates the clutch. I tried several Freelanders before this one, similar age etc, and they all seemed similar. Is this normal? It is a bit of a pain at lights or in traffic because it feels so heavy. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
EggNChips Posted December 17, 2013 Share Posted December 17, 2013 Probably the Concentric slave cylinder is on it's way out. On the TD4 there is a bleed nipple for the clutch, try bleeding it. It may help for a few days, then return to the way it was. Then try the master cylinder as it's quick and easy to change. If that doesn't fix it, then I'm afraid it's a new clutch and concentris slave, which aint cheap on labour Quote Link to comment Share on other sites More sharing options...
