clive-240 Posted January 2, 2014 Share Posted January 2, 2014 Can anyone advise if there is a reversing light switch on an Auto gearbox I found that my reversing lights had decided to stop working last night been on the net but cant seem to find anything and the haynes manual is only good for starting a fire with. Quote Link to comment Share on other sites More sharing options...
bear Posted January 2, 2014 Share Posted January 2, 2014 Hi Clive, Do a search for "Rave". This is the downloadable LR workshop manual and should help. Griff Quote Link to comment Share on other sites More sharing options...
clive-240 Posted January 2, 2014 Author Share Posted January 2, 2014 been doing a little digging this after noon found that if you move the gear selector slightly passed or just before it clicks into position the lights come on need to look at it bit more to see if I can find out why but looking at the forecast for the next couple of days think I will be leaving it Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 3, 2014 Share Posted January 3, 2014 Sounds like you either need to check the adjustment of the existing selector-switch, or replace it. Quote Link to comment Share on other sites More sharing options...
Boydie Posted January 19, 2014 Share Posted January 19, 2014 Its a combination gear shift lock-out and reversing switch, its located on the LH side of the box and held in position with a 10mm hex head bolt and clamp. the connection is a 4 pin plug. The switch is bloody expensive so you might want to see if your not-so-frendly local Land Rover wreaker has a good one for sale. Either way replace the rubber "O" ring to ensure you dont have an oil leak. Quote Link to comment Share on other sites More sharing options...
