need4speed Posted January 2, 2014 Share Posted January 2, 2014 Having a look at the site to see how much the crimp-type DB37 connectors are but everything listed as out-of-stock. How much are these? Was quite happy to use the solder-type but discovered that the solder buckets are not at all happy about accepting 1mm wire. In fact after some research find that 20awg (or equivalent) is the max size recommended for the solder-type.. Quote Link to comment Share on other sites More sharing options...
zardos Posted January 2, 2014 Share Posted January 2, 2014 May be not what you want but interesting (because I think megasquirt's use of a db37 connector is a bad idea)http://uk.rs-online.com/web/p/interface-modules/2929616/ (but not cheap) But may be what you want http://uk.rs-online.com/web/p/crimp-d-sub-connectors/0481077/ Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 2, 2014 Share Posted January 2, 2014 i HAVE SOME ALREAY SOLDERED d37 WITRH PIGTAILS NOW !rEDOING WEBSITE AND HAVE A STUPID AMOUNT OF DIFF WORK IN SO UNDER THE COSH ARGH caps lock is on !!Give me a ring there are more options now, crimp, s9older, alreay soldered and pigtail <yoda> yes Spoil you I do see </yoda> Nige Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 2, 2014 Author Share Posted January 2, 2014 Nige, it appears that you have taken your phone number off the site... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 3, 2014 Share Posted January 3, 2014 Was quite happy to use the solder-type but discovered that the solder buckets are not at all happy about accepting 1mm wire. In fact after some research find that 20awg (or equivalent) is the max size recommended for the solder-type.. If you tin the wire AND the bucket and then hold them together, just touch with the iron so the solder flows and the wire sits into the bucket without splaying. It can end up quite close, heat-shrink over each terminal is a very good idea IMHO. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 3, 2014 Share Posted January 3, 2014 I hiding HMTLing my brain to further mush..... than it is now ................. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted January 7, 2014 Share Posted January 7, 2014 Nige, your typing is sheer comedy gold Quote Link to comment Share on other sites More sharing options...
