ananab Posted January 7, 2014 Share Posted January 7, 2014 Hi, I've got a 1994 90 (was FFR but has had the 24v system removed) and was just wondering if any one had any ideas for roof insulation/ lining to help cut out the condensation. I've been looking at proper headlining, but the cost is wickedly expensive. I was toying with using some high density insultion foam (15mm). Any ideas? Quote Link to comment Share on other sites More sharing options...
TJN Posted January 31, 2014 Share Posted January 31, 2014 Buy the FFR winterizing kit on ebay and cut out the foil backed ruubber and spray glue that to the roof. makes for great insulation. Did this in the 130. Quote Link to comment Share on other sites More sharing options...
=jon= Posted January 31, 2014 Share Posted January 31, 2014 I used laminate floor underlay (the 1mm blown foam stuff) on mine, stuck on with high temp (important!) spray glue. Worked a treat, and was basically free as I had a load left over... Quote Link to comment Share on other sites More sharing options...
ananab Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks guys Quote Link to comment Share on other sites More sharing options...
ananab Posted February 18, 2014 Author Share Posted February 18, 2014 Well inside is done. High density foam panels, camping mats, silvered bubble wrap and some very cheap vinyl upholstry material (unfortunately it's black and white cow pattern). It's made a massive difference to noise and condensation. Quote Link to comment Share on other sites More sharing options...
