Sign in to follow this
M.I.B
Heated Front Screen - 2 Tab or 3 Tab?
A few heated front screens on offer, and a fair few people doing "plug and play" wiring kits.
I know that some skilled person on here has drawn up a "DIY" wiring diagram, but when you price up all the components and postage from each of the suppliers (ouch) it cost the same as a complete kit with wires all fitted ready to go.
The trouble is that the screens are all 2 tab, and the plug and play kits for my fascia/switch style (06MY) are for 3 tab.
Can I fit a 2 tab heated front screen and just use 2 of the feed wires? I would leave the thiird wire wrapped in insul tape for the day when the heated screen gets replaced by Autoglass with a 3 tabber.
Thanks in advance.
Share this post
Link to post
3 Tab screen is a generic replacement screen - OEM (factory) front heated screens have only 2 tabs.
So here's the question - If you have wiring for a 2 tab screen ( ie factory wiring) what happend when Autofit want to give you a 3 tab screen?
Share this post
Link to post
My 06 td5 XS loom was factory fitted for a 2 tab screen and the HFS relay was melting at the terminals due to current draw. My new screen is a 3 tab and I've split the load and feeds over 2 relays. Can't see an issue leaving the unused feed suitably insulated and tucked away for future use...but I'd keep an eye on the relay for signs of overheating.
Share this post
Link to post
