Broken glow plug
L835
I'm giving the top end of my 300tdi a refurb, but one of the glow plugs has broken off, about 40mm in. I have tried tapping it out while the head is off, but its absolutely solid. The bore seems to be a taper fit. Is leaving it in likely to cause any damage, or will it remove itself when the head is hot and compression in the cylinder persuades it to leave?
Thanks
Richard
