white90 Posted October 14, 2006 Share Posted October 14, 2006 ebay item 130034820532 anyone know owt about this ? Quote Link to comment Share on other sites More sharing options...
D9OSV Posted October 14, 2006 Share Posted October 14, 2006 The Quaife center diff is a torque bias Diff............ You don't need it mate, leave it for the racers Your far better of with a full time locking center differental (Standard) Jim Quote Link to comment Share on other sites More sharing options...
white90 Posted October 14, 2006 Author Share Posted October 14, 2006 cheers Jim it is nice and shiney though isn't it MMMMMMMMMMShiney MMMMMMMMMMMM Quote Link to comment Share on other sites More sharing options...
D9OSV Posted October 14, 2006 Share Posted October 14, 2006 Yes, but you can't see it when it's in the trans box......... And more importantly, nor can anyone else.... Jim Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 14, 2006 Share Posted October 14, 2006 Dam! I wish I'd seen that! For the price it went for I'd have bought it without thinking. I'm already on one centre diff this year and that was a properly built one with a solid cross shaft P.S. Jim, bling give you that warm fuzzy feeling inside even if you can't see it Quote Link to comment Share on other sites More sharing options...
D9OSV Posted October 14, 2006 Share Posted October 14, 2006 Will if you runn with the center diff locked offroad, you won't break it....Full stop It's when you dick about with it disengaged that you mess them up. Here endth the lesson..... Jim Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted October 14, 2006 Share Posted October 14, 2006 A peice of useless centre diff trivia for the rivet counters among us. In the mid 1960's Rover breifly offered a 4 pinion limited slip diff option for front and rear diffs on series 2A LandRovers.It was known as the Salisbury Power Lock. Unfortunately the side and pinion gears were a bit small and proved to be even less durable than LandRovers existing 2 pinion diff so the option was discontinued after only a few hundred were made. When the first RangeRovers were built they had limited slip centre differentials for a breif period. I rebuilt an early Rangey centre diff once that had broken both cross shafts and 2 of the 4 pinion gears as well as worn limited slip clutch plates. I found that these parts were identical to those off the old series 2A Salisbury Power locks which I had in stock.Only the spline in both side gears differed. The later non limited slip centre diffs (both LT95 and LT230)continued using the same pattern gears and shafts. Bill. Quote Link to comment Share on other sites More sharing options...
will_warne Posted October 15, 2006 Share Posted October 15, 2006 Will if you runn with the center diff locked offroad, you won't break it....Full stop It's when you dick about with it disengaged that you mess them up. Here endth the lesson..... Jim Yeah, unless it pops out on a hill climb and then goes bang I never like running the diff open off road for that reason. Since then I've tweeked the linkage a little more to stop this happening. Quote Link to comment Share on other sites More sharing options...
