Gareth Dickens Posted March 6, 2014 Share Posted March 6, 2014 Lubricating the threads may help considerably, though that could make it easy for the nut to come undone later. You could lubricated them for the crushing job, mark the nut again, then undo it to clean the threads off before refitting. Remember to peen the nut when it's tight. What about lubricating the threads with Loctite? Lubricated when tightening and then dries to prevent the nut from loosening? Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 6, 2014 Share Posted March 6, 2014 The trouble is that you have to tighten the nut incrementally to check for bearing play, just a bit at a time so you don'e overload them. It all depends on how quickly the Locktite goes off, and i my experience it's too quick. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 6, 2014 Author Share Posted March 6, 2014 It'll have to wait a wee while...tax reminder came today...and on checking up..the 88's MoT is nearly up too! Need to do some work on that and get it in pronto, don't want to be late. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted March 6, 2014 Share Posted March 6, 2014 The trouble is that you have to tighten the nut incrementally to check for bearing play, just a bit at a time so you don'e overload them. It all depends on how quickly the Locktite goes off, and i my experience it's too quick. Wicking grade applied after assembly? Quote Link to comment Share on other sites More sharing options...
Gareth Dickens Posted March 7, 2014 Share Posted March 7, 2014 The locktite threadlocker I have gives plenty of time. I think you have a good 30 minutes at least. I will test some. I wasn't refering to the superglue stuff. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 8, 2014 Author Share Posted April 8, 2014 I ordered new bearings and seals yesterday. I thought if I'm going to strip the diff out and put the 3.54 diff in, I might as well have new bearings....otherwise knowing my luck it'll only throw the bearings in a month or two.... Need to do seem heavy reading now in peoples threads, and Dave has leant me his workshop manual too. This will be fun.... Any volunteers for Easter weekend?!!! Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 8, 2014 Share Posted April 8, 2014 I just changed the pinion bearings on mine. Seem good till now 1 year down the line. Pulling the bearings off the carrier is going to be fun! Good luck! G Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 9, 2014 Author Share Posted April 9, 2014 we'll manage....hopefully! I've got a couple of pullers, hopefully they'll move Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 18, 2014 Author Share Posted April 18, 2014 Got it stripped today...seemed very reluctant to come out of the case, hope I haven't stretched it. All the bearings and seals are here, I'm going to pop the old bearings off, transfer the shims from the Series diff to the 110 diff, then fit the new bearings to the 110 diff....I'm thinking that should be fine. I have spring balance to check the pre-load with a bit of string wrapped round the input flange, with luck that will suffice and I won't have to do a complete strip down and set up as from new. Off to read posts now! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 23, 2014 Author Share Posted April 23, 2014 As we've now established this isn't a brake fault, I've started a thread on the Salisbury rebuild here: http://forums.lr4x4.com/index.php?showtopic=89185&hl= Thanks for everyone's help 1 Quote Link to comment Share on other sites More sharing options...
