jules Posted October 15, 2006 Share Posted October 15, 2006 is there anything I need to know before I start removal.....(can't find my Rave CD Quote Link to comment Share on other sites More sharing options...
white90 Posted October 15, 2006 Share Posted October 15, 2006 Remove keys from ignition remove both battery leads, negative first then wait 10mins before commencing work. remove Torx bolts from back of wheel support airbag module and do not let it hang on the wires, disconnect multiplug from airbag module and store somewhere safe face upwards. it suggests some where like a locked luggage compartment well away from you and anyone else. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 15, 2006 Share Posted October 15, 2006 And don't wear a crackly synthetic fleece when you are doing it Quote Link to comment Share on other sites More sharing options...
jules Posted October 15, 2006 Author Share Posted October 15, 2006 And don't wear a crackly synthetic fleece when you are doing it I'm only replacing a air bag Quote Link to comment Share on other sites More sharing options...
GBMUD Posted October 15, 2006 Share Posted October 15, 2006 I'm only replacing a air bag Is this a suspension or a steering wheel airbag? Chris Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 16, 2006 Share Posted October 16, 2006 Is this a suspension or a steering wheel airbag?Chris Good point. I assumed the latter! Not sure ones choice of outer leisurewear would be significant in replacing suspension components Quote Link to comment Share on other sites More sharing options...
jules Posted October 16, 2006 Author Share Posted October 16, 2006 Good point. I assumed the latter! Not sure ones choice of outer leisurewear would be significant in replacing suspension components Sorry Rear air spring... done loads of Air bag replacements with the racer's etc mainly removal but the camal had a new wheel fitted before I sold it.. did it yesterday took about 30 min from jacking up to droping back down.. its easy takes longer to change a normal spring Thanks anyway and the misses found the rave about an hr after I finished.. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 16, 2006 Share Posted October 16, 2006 I'm only replacing a suspension air bag Jules I added the all important word you missed out rather a critical under use of words IMHO Quote Link to comment Share on other sites More sharing options...
jules Posted October 16, 2006 Author Share Posted October 16, 2006 Oops! Quote Link to comment Share on other sites More sharing options...
