pgrbff Posted February 16, 2014 Share Posted February 16, 2014 My wipers have developed a mind of their own, intermittent doesn't work, won't switch off etc. I'm guessing it's the relay but I'm not sure where the relay is. There is a large red relay tie-wrapped in the fuse box above the transmission tunnel. Is that where it is normally found? Is it normally tie wrapped on? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 16, 2014 Share Posted February 16, 2014 When you replace the relay you can fit a VW one that will give you variable intermitant wipe if you like. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 16, 2014 Share Posted February 16, 2014 btw here is the thread with part number etc http://forums.lr4x4.com/index.php?showtopic=20391 Quote Link to comment Share on other sites More sharing options...
pgrbff Posted February 16, 2014 Author Share Posted February 16, 2014 Unfortunately I have already ordered the original Lucas part. I would like to know where the relay is though? I did search "wiper relay" but had no hits, which did seem strange. Quote Link to comment Share on other sites More sharing options...
western Posted February 16, 2014 Share Posted February 16, 2014 should sit behind the fusebox metal panel. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted February 16, 2014 Author Share Posted February 16, 2014 Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted February 16, 2014 Share Posted February 16, 2014 as to fixing it in place, the normal way is to slide it on to one of the relay tabs along the bottom of the metal panel, same as the other relays. Quote Link to comment Share on other sites More sharing options...
pgrbff Posted February 16, 2014 Author Share Posted February 16, 2014 If it's the one I think it is it seems bigger than the other two which from memory are on the R/H side and seem to be in their original position. The larger relay is on its side and held in place with a cable tie on the L/H side. I'll take a pic tomorrow. Someone has installed an immobiliser, Cobra?, that does nothing useful. If you don't disarm it before starting the ignition none of the warning lights come on as expected except a faint glow from the charging light. If you do disarm it the warning lights work as they should. Armed or disarmed the car will start anyway. Quote Link to comment Share on other sites More sharing options...
