tuskar Posted February 23, 2014 Share Posted February 23, 2014 Could anyone tell me please when the r380 gearbox output shaft got the cross drilled upgrade to prevent premature wear . either an index number or year . Mine is a late 95 , with no apparent backlash. Thanks Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 5, 2014 Share Posted March 5, 2014 No idea, remove the end plate and bearing (alloy) plate and see if your gearbox shaft is worn, if its not it's a safe bet your transfer gearbox input gear has been cross drilled but if you're not certain remove it, it will slide out. If it has been cross drilled happy days, if it is'nt cross driil it and put it back in, it's as easy as that. I put a explanation on how to cross driil the gear earlier on this year. Quote Link to comment Share on other sites More sharing options...
tuskar Posted March 6, 2014 Author Share Posted March 6, 2014 Thanks again Boydie. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 8, 2014 Share Posted March 8, 2014 I'm pretty sure the cross drilling started on the mid-series LT77S and that all R380s had it. Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 9, 2014 Share Posted March 9, 2014 Mine was built in 1998 and first registered in Australia in June 1999 and the gear had been cross drilled, my mates 2 door built in 1996 was not. Quote Link to comment Share on other sites More sharing options...
tuskar Posted March 9, 2014 Author Share Posted March 9, 2014 There is only one way to find out and look in there. Thanks guys Quote Link to comment Share on other sites More sharing options...
