TJN Posted February 24, 2014 Share Posted February 24, 2014 Ok so a friend has a 24V FFR s111 that wont start. Cant seem to get a spark but how can i test the feed from the coil when all the cables are shrouded in metal hose? Ideas please. Thanks TJ Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 25, 2014 Share Posted February 25, 2014 you can substitute a normal plug lead? the covered ones are only there for radio noise suppression Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 25, 2014 Share Posted February 25, 2014 You can't use standard leads because of the connections, but it is unlikely that all the leads have failed simultaneously - if none of the plugs spark, then the fault is likely to be between the ignition switch and distributor. Quote Link to comment Share on other sites More sharing options...
