tedsmart Posted February 26, 2014 Share Posted February 26, 2014 Hi, Has anyone put a spare wheel holder on the bonnet of a 1996 300Tdi, I'm getting reports that it may crack the bonnet, I have put the strengthening braces in the frame and plan to put checker plate on the top, is there really that much difference between the series 3's bonnet as I had one of these and can't remember any issues? Quote Link to comment Share on other sites More sharing options...
L835 Posted February 26, 2014 Share Posted February 26, 2014 Have bonnet mounted spares on 1989 and 1990 110s - no issues! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 26, 2014 Share Posted February 26, 2014 I had a spare mounted on the bonnet of my 1995/6 Defender for ten years and over 100,000 miles. No problems. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 26, 2014 Share Posted February 26, 2014 Does this help Make sure it's got the black metal stiffeners. Mike Quote Link to comment Share on other sites More sharing options...
tedsmart Posted February 26, 2014 Author Share Posted February 26, 2014 Thanks miketomcat, that's just what I was after. I notice you have the scissor prop, have you had any issues with that and the weight of the wheel on the bonnet? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 26, 2014 Share Posted February 26, 2014 I strap my spare down to the bonnet. I also use series two clasps to hold the bonnet. Both stop the spare and the bonnet flapping about when driving. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 26, 2014 Share Posted February 26, 2014 Thanks miketomcat, that's just what I was after. I notice you have the scissor prop, have you had any issues with that and the weight of the wheel on the bonnet?Unfortunately I can't help with it's use as this is the donor for the ibex so I've never driven it.Mike Quote Link to comment Share on other sites More sharing options...
L835 Posted February 26, 2014 Share Posted February 26, 2014 Changed my scissor prop for a solid one, in view of the weight.... Quote Link to comment Share on other sites More sharing options...
Guest Posted February 26, 2014 Share Posted February 26, 2014 I used to have my boost alloy on the bonnet of my 03 TD5 I had chequer plate on the bonnet and fitted a new style rear door carrier to the bonnet and used the spare wheel buffers to stop the wheel bouncing around. It was on there for over 30k of very bumpy roads with no cracks or damage. It does make the bonnet heavy but the closer to the back the better. The second and bigger PITA is that it makes the washers unusable at any speed over 45mph!! This is the same for single or two washers the air pushes around the wheel. I guess that you could go down the pipe on the wiper route but the air in the windscreen was just a mess. Jason. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 26, 2014 Share Posted February 26, 2014 Agreed Jason. For some reason I found moving the jets on the bonnet nearly under the spare wasn't a problem Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 26, 2014 Share Posted February 26, 2014 Interesting... I'm putting a spare on the bonnet over the next few months, so I'd better be off to the scrapper to look for some Citroen rear windscreen wipers Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 26, 2014 Share Posted February 26, 2014 Yes and no David. I'll send you the measurements of my bonnet jet position if you like. As Jason says, The water pulls away to the front. Mine don't anymore. Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 27, 2014 Share Posted February 27, 2014 I converted my bonnet to carry a spare using the LR kit - the four buffers, the two black steel braces to reinforce the frame (as per the photo) and the securing ring and peg assembly. I later added the MoD/Came Trophy type bonnet clasps, as used on MoD Series LRs before the 90 and 110, and on SIs before that, because the bowden cable for the bonnet release catch would gum up in dusty conditions. They weren't necessary for stabilising the bonnet, though - the buffers on the leading edge of the bonnet which sit against the slam panel did fine. Just remember to add the second pair - plain bonnets only have two buffers, but those with spare wheels should have four. Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted February 27, 2014 Share Posted February 27, 2014 Where do the second pair of buffers go please? I have an ex MOD 110 with bonnet spare, but only two of the buffers in the slam panel. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 27, 2014 Share Posted February 27, 2014 Where do the second pair of buffers go please? I have an ex MOD 110 with bonnet spare, but only two of the buffers in the slam panel. Easily seen in Mikes pic of the bonnet up. Quote Link to comment Share on other sites More sharing options...
AndrewHorsfield Posted February 27, 2014 Share Posted February 27, 2014 Cheers. I should have gone to Specsavers Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 28, 2014 Share Posted February 28, 2014 My CT110 with its bonnet mount is pretty FUBAR, I think its touching the top of the turbo heat shield bracket now, but I think thats mainly come from people jumping up and down on the bonnet, I think its just deformed as apposed to cracked anything... Solid prop is a must, and be prepared to look under your bonnet an awefull lot less... Quote Link to comment Share on other sites More sharing options...
