Scotts90 Posted February 28, 2014 Share Posted February 28, 2014 Has anyone stone guarded the underside of their tub? More specifically the inner arches? I'm aware the tub is almost all alloy/aluminium and factory spec appears to be the lightest dusting of paint known to man, just wondered if it's worth the effort to try and add a layer of sound deadening and a little added weather protection. The plan is to etch prime all the bare areas then seam seal and prime as usual. Do I topcoat then waxoyl, or schutz/gravitex then topcoat. The bad point is creating a water trap if the stoneguard gets breached. Any advice or experience appreciated Scott Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 28, 2014 Share Posted February 28, 2014 I painted on tetroseal last time I waxoyled and I've been pretty impressed with its coverage and protection so far. that was over a hear ago now. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted February 28, 2014 Share Posted February 28, 2014 I stuck two layers of Flashband, giving it a blast with a heat gun and a roller to work it into every corner, then put a thick coat of Raptor coating in top, seems to have taken really well. Only time and mileage will tell, the wagon is off for its MOT this weekend! Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted February 28, 2014 Share Posted February 28, 2014 I was thinking just the same thing yesterday driving along in the rain listening to the spray hitting the wheel boxes. I reckon that the most effective solution would be an extra skin, either a plastic inner arch nicked out of something else, or a piece of ali folder round with some sticky closed cell stuff on the back of it. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 28, 2014 Share Posted February 28, 2014 Someone did just that on the Defender2 forum recently (I think it was that one). Noise suppression would be my reason, the trick would be doing it without creating a water/mud trap. Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2014 Share Posted February 28, 2014 spayed the underside on my rear tub with black waxoyl before we fitted the body onto my new chassis. there was no protection there. Quote Link to comment Share on other sites More sharing options...
Boris113 Posted February 28, 2014 Share Posted February 28, 2014 I painted mine with etch primer and some combi colour that was lying in the shed, then a very thick covering of waxoyl/hammerite gloop. If I was to do it again, I'd try the raptor/line-x stuff, simply because the waxoyl is messy and never dries. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted February 28, 2014 Author Share Posted February 28, 2014 Raptor coat sounds good. Thanks for the ideas chaps Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 28, 2014 Share Posted February 28, 2014 Years ago (decades, actually) I riveted some corriboard - the plastic corrugated paperstuff onto the ribs of the wheelboxes on my 88". It made a huge difference to the noise from stones, and the mud just washed off, but when I do it next time I'll put flashband on first. G. Quote Link to comment Share on other sites More sharing options...
Litch Posted February 28, 2014 Share Posted February 28, 2014 When I fitted a brand-new (factory fresh) tub to mine I Waxoyled it and it has been fine. The comment about Waxoyl never going hard is just the point, it is flexible and more resistant to chipping than a hard coating. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted February 28, 2014 Author Share Posted February 28, 2014 My main dislike about waxoyl and similar non-setting coatings is their limited scope for cleaning. I like to be able to wash/scrub all the crud from the inner arches and underside and whilst not impossible with waxoyl it's a lot easier with a hardened finish Quote Link to comment Share on other sites More sharing options...
Litch Posted March 1, 2014 Share Posted March 1, 2014 My main dislike about waxoyl and similar non-setting coatings is their limited scope for cleaning. I like to be able to wash/scrub all the crud from the inner arches and underside and whilst not impossible with waxoyl it's a lot easier with a hardened finish Not difficult at all. My 90 has been Waxoyled for 15-years now (with occasional re-applications) and the muck practically falls off. I pride myself if keeping the underside clean (no pressure washer required, just regular cleaning with a hose-pipe) so rot never has a chance to take hold. The Army were good at teaching how to get into ALL the nooks & crannies which also makes the vehicle more pleasent to work on. Come MOT time there is always a comment along the lines of how nice it is to check a vehicle where you don't get muck falling in your face all the time. Quote Link to comment Share on other sites More sharing options...
smallfry Posted March 1, 2014 Share Posted March 1, 2014 What about fixing some plastic trailer mudguards up inside the arch................or even some HGV type things. I have got some small trailer ones here ehich have a flat top and could be fixed to the ribs in the wheelarches. These ones are too small for the job, but I have seen bigger ones Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted March 2, 2014 Author Share Posted March 2, 2014 Not difficult at all. My 90 has been Waxoyled for 15-years now (with occasional re-applications) and the muck practically falls off. I pride myself if keeping the underside clean (no pressure washer required, just regular cleaning with a hose-pipe) so rot never has a chance to take hold. The Army were good at teaching how to get into ALL the nooks & crannies which also makes the vehicle more pleasent to work on. Come MOT time there is always a comment along the lines of how nice it is to check a vehicle where you don't get muck falling in your face all the time. This is how I clean I like mine...sad but hey-ho. Never had any problems selling cars on when they're kept like this tho My astra gsi Vectra gsi Mk3 astra gsi Yes, I like my vauxhalls too lol At MOT time the testers put rags on the beam jack so as not to damage the paint. Back on topic though, on one of the rally are we built the Kevlar guards were only lasting a couple of events before thinning through so we used curved section from blue chemical barrels to form inner arch guards and deflectors. Those worked a treat Quote Link to comment Share on other sites More sharing options...
