Adam001 Posted March 2, 2014 Share Posted March 2, 2014 Hi, Can someone measure the length of a R380 from a Defender, ideally from the LT230 Mating face to the Engine Mating Face, but just the length of the bell housing would be great. From what I can see the discoverys are identical in length, just the tailhousing being different. and V8s have the same input shaft length but the splines are a different length and the spigot bearing dia is different. It's to work out the engine and transmission for a modified engine layout. (currently have a LT77 setup). Hunted the internet for a while but good information is fairly limited Thanks, Adam Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 2, 2014 Share Posted March 2, 2014 Main box from LT230 mating surface to bell housing mating surface 387mm Length of bell housing 246mm Measured from Defender 300 TDI R380 Quote Link to comment Share on other sites More sharing options...
Adam001 Posted March 2, 2014 Author Share Posted March 2, 2014 You star, thank you very much Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 2, 2014 Share Posted March 2, 2014 No probs, it's sitting in the middle of the shed floor being tripped over so measuring was easy. Must get around to sending it for recon. Quote Link to comment Share on other sites More sharing options...
fourwzzy Posted March 14, 2015 Share Posted March 14, 2015 guys! how long is combination of 300tdi with r380 and lt230?) from fan to handbrake drum or just lenght of gearbox and transferbox. from the beginning of bellhousing to handbrake drum asking because want to put this combination in Series 3, but have serious doubts about capacity of space under bonnet thank you! Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted March 15, 2015 Share Posted March 15, 2015 You will struggle to get a r380 in a series unless it's a "short r380" so it's the same length as a lt77 Quote Link to comment Share on other sites More sharing options...
