Oakmaster Posted March 18, 2014 Share Posted March 18, 2014 While not really a fan of DLRs I have always driven with my lights on, Scandinavian style (or at least sidelights) My 11 mile daily drive includes of single track roads, blind corners, hidden dips, and large agricultural assets (and sometimes agricultural asses) coming the other way. I think that if you go out of your way to make yourself visible, then you are reducing the likelihood of being involved in a collision. (but I'm always happy to hear views to the contrary) My last three 110 CSWs (300 Tdi. Td5 and Puma) have had their DimDip units fail so I'm considering fitting DLRs instead. I'm having trouble imagining how or where you might mount them so as not to spoil the lovely lines of my Landy, so Id be very pleased to see pictures from anyone who has done this. At the same time I’d pleased to hear the opinions of others regarding any aspects of DLRs including buying installing and wiring, or anything else relevant – some times you just don’t know what it is you don’t know! Thank you Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2014 Share Posted March 18, 2014 I fitted crystal headlights that have built in sidelight, dim dip just kept failing,the new additional sidelights give nearly the same extra lights up front as the defunct dim dip. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 18, 2014 Share Posted March 18, 2014 I've seen bumpers with built in DLR's, maybe that would be an option for you without affecting the lines of your 110? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 18, 2014 Share Posted March 18, 2014 There's an example here http://www.flatdoguk.com/defender-bumper-with-drl%27s~783 this is just the first one I found when googling so it's not a recommendation as I haven't ever bought from this shop. Quote Link to comment Share on other sites More sharing options...
jbs Posted March 19, 2014 Share Posted March 19, 2014 I drive round with my headlights on during the day-It really does help!! John Quote Link to comment Share on other sites More sharing options...
Green Bob Posted March 19, 2014 Share Posted March 19, 2014 I've thought about the DRL thing and where I would fit them if they suddenly became a necessity for all vehicles and I think rings of LEDs around the headlights would look ok... Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 20, 2014 Share Posted March 20, 2014 Just wire your sidelights to always be on with the ignition? At least those aren't horribly annoying. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted March 20, 2014 Share Posted March 20, 2014 Just wire your sidelights to always be on with the ignition? At least those aren't horribly annoying. I would do this too... Simplest option to accomplish and no worry about fitting etc. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 20, 2014 Share Posted March 20, 2014 Not knowing the answer to this, what is the legal requirement around sidelights? Is there a requirement to have them for when parked on unlit roads or something along those lines? If so you'd need to think about how you accomplish the rewiring task. Quote Link to comment Share on other sites More sharing options...
Edlen Posted March 20, 2014 Share Posted March 20, 2014 https://www.gov.uk/general-rules-all-drivers-riders-103-to-158/lighting-requirements-113-to-116 explains Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 20, 2014 Share Posted March 20, 2014 How about swapping your front side light units for rear stop & tail and using the clear lens. Then wire the side light to the 6w filament and an ignition feed to the 21w filament through a relay that isolates it when the side lights are switched on. I think that's how Volvo basically did it. Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted March 21, 2014 Author Share Posted March 21, 2014 How about swapping your front side light units for rear stop & tail and using the clear lens. Then wire the side light to the 6w filament and an ignition feed to the 21w filament through a relay that isolates it when the side lights are switched on. I think that's how Volvo basically did it. I think this is a very interesting idea - and well worth following-up especially if you were to use LED bulbs (to reduce the heat - 21W bulbs seem to severly reduce the the lifespan of a light fitting if left on - for example if you used a rear stop & tail fitting as a rear fog light) Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 21, 2014 Share Posted March 21, 2014 Standard lights used with 21w bulbs do have a habit of melting. I've bought some nas size but flat face led side lights from Bolton bits for the ibex they have a side light wire and a drl wire. The drl setting is a lot brighter not sure whether I'll wire them up or not yet. Mike Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 21, 2014 Share Posted March 21, 2014 I must have replaced 5 sets of side light mounts on the 110 in the last 5 years - all because of 21w bulbs; they are just too hot unless you use military lamps; and of course they are illegal. So I moved down to 10w bulbs... The best mix is a nice bright LED in a Military lense Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 21, 2014 Share Posted March 21, 2014 I forgot how much damage the 21w bulbs do, the led idea sounds better. the idea was to keep the lighting looking as standard as possible. Quote Link to comment Share on other sites More sharing options...
tuko Posted March 22, 2014 Share Posted March 22, 2014 You could buy 8 or 10 1W eagle eye LED's and install them parallel to create a nicely built-in DLR like this image: Eventually I will make mine like this once I get the other projects out of the way. Todd. Quote Link to comment Share on other sites More sharing options...
